Lift Manufacturer question for 88 yota IFS
I have an 88 pickup with IFS and would like to lift it. What manufacturers makes a decent lift? What do you have? Do you like it? What don't you like about it? Am NOT interested in full axle swap. Thanks in advance
What size tires do you want to run on your truck? I'm running a 33x10.50 stock on my 91 pickup and it work really well offroad. If you are wanting to run something larger then you might want to run a 4inch suspension lift. I would suggest Pro Comp or Superlift if you really want to spend the money on an IFS lift.
Rancho is not the way to go if you want a simple bolt on all around lift. I think the pro comp is the cheapest well rounded choice. Trailmaster is fine but I think you have to trim away some on the lower a-arms mounts where the stock truss bolts to. Superlift has a good name to stand behind but never seen one in use.
From what is sounds like, I think ball joint spacers and some t-bar tweek for a 2-3" lift will suit you best. Cheap and can clear 33x12.50's.
I ran a Superlift suspension setup with rear springs on my 92 pickup for about 3-4 years before selling the truck. The front took a little more work then I would have thaught to put on , but the system was very nice.
If you look at a Superlift kit and a Rough Country lift side by side they appear to be made at the same plant. They both use 1 piece drop brackets for extra strength too.
The kicker is the RC kit is like $220 less than the Superlift.
Flying91
45
04-11-2024 04:39 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
scottyg486
07-19-2015 05:34 PM
