Leaking coolant
Hey it's been a while since I've posted anything. So I have a problem with my 94 Toyota pickup 22re leaking coolant. I have replaced the radiator, check the hoses, & also there is no evidence for leaks excepts the the back end of the motor on the transmission where it looks wet. Any help would be greatful because I have ran out of ideas what it could be.
if there are no hoses or anything that can leak back there then your head gasket may have failed... do a leak test and find there source if you dont know what the cause is dont throw random money at it
there's a heater hose back there, along with a head plate, which will be a royal pain to remove and replace the gasket..pray it's the hose...
Originally Posted by Black_1985_SR5
(Post 52157048)
| All times are GMT -8. The time now is 05:38 AM. |
