leaking coolant
i have searched and cant find out why my truck is leaking coolant its coming off the oil pan and it is also on the power steering gearbox i checked its not coming from the heads no coolant anyhigher than the oil pan it looks to me like it is near the water pump and it has not overheated nor does it take forever to heat up what do yall think?
Waterpump is probibly gone. How long since it was replaced? Be carefull with the 3vze cooling system, you do not want to overheat a 3vze ;)
what would it cost to replace?
Well, usually when you do a waterpump, you will replace the timing belt and tensioner while you're in there. Its tough to get too so its cheaper in the long run..
Using only toyota parts... 250ish + labor? Toyota prices are higher up here in canada so.... |
thats not as bad as i thought it was going to be i guess ill be taking it to the shop tommrrow thanks jay
