YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   LCE Header/Starter (https://www.yotatech.com/forums/f116/lce-header-starter-303600/)
jodee95jodee95 Feb 28, 2018 01:40 AM
LCE Header/Starter
Hello All, just checking to see if anyone has knowledge about my issue. 1988 4 Runner all original clean truck 3VZE I added LC Engineering Headers a while back and have not regretted it I like the way the truck sounds system has held up well it’s ..a good set of pipes. Only problem is I am starting to develop some starter issues. Clicks every so often becoming more frequent. So, I must tackle that starter I thought for sure the bugger of a header would need to come off first I have heard people complain about a straight forward starter change with no header on the truck. But LCE Tech support people are telling me the starter can come OFF the truck without removing the header first Does anyone have knowledge about this? It’s so tight in there I don’t see how but I am a very novice mechanic, Thank you for your help
L5wolvesf Feb 28, 2018 05:47 AM
I would also check for postings here regarding starter relays - particularly those that RAD4runner has responded to. See if the incorrectly wired or missing starter relay issue is possibly your situation.
Also whenever I've had headers running close to the starter I bought or fab'ed a shield.
RAD4Runner Feb 28, 2018 11:42 AM
Originally Posted by jodee95jodee95 (Post 52392090)
...Clicks every so often becoming more frequent. ...
A problem well-stated is almost solved.
How can you expect us to help if we do not know EXACTLY WHAT CLICKS AND WHERE?
Pls see my signature.
jodee95jodee95 Mar 1, 2018 08:28 AM
Clicking sound is from the starter/ solenoid...
RAD4Runner Mar 1, 2018 11:44 AM
Does it sound energetic or faint?
Mind sharing picture of your starter RELAY, the pin diagram on the relay itself and the pins on the relay and the socket?
jodee95jodee95 Mar 1, 2018 04:28 PM
Sorry I guess I did not explain this correctly. The starter on my 3VZE on my 88 4Runner is BAD it must come out LC Engineering Tech support tells me the starter can be removed without removing the header first. That looks almost impossible to me. Has anyone completed this task Thank you….
