LCA replacement
Ok, So I am in the process of wire wheeling the frame on my 94 22re 4x4 pickup. I noticed that the front lower control arms are pretty rusty and look they need replaced. Problem is I can;t find replacement lower control arms. Maybe my google skills are failing me tonight. Any one have a link to some new arms, aftermarket or stock oe replacement? Thanks
Check cl I even have 2 sets on their
Originally Posted by Jcrawl94
(Post 52281039)
Ok, I may have found a control arm for the truck. Now fro the fun part. While I am in there should I do the upper and lower ball joints and tie rod ends? They do not seem to have any play. I will probably do the same to both sides, then get an alignment. Thoughts? Sounds like I will probably have to get new camber bolts, sounds like I will probably cut them out if rusted to the sleeve. Thanks
Depends on what your plans are if you plan on keeping this vehicle .
It can`t hurt if you have the extra money to rebuild the whole front suspension now. Just how bad was your LCA rusted??:welder: I must say I looked and could find no listing for the LCA`s either for that year 4x4 |
There is a area about 1/2 inch by 3 inch completely rusted away.
| All times are GMT -8. The time now is 02:23 PM. |
