Just did the starter relay mod -wow!
Connected the starter relay to a dedicated 12V 30A fused line per RAD4runner’s instructions and all i can say is WOW!
I was skeptical(doubting Thomas) - i already had rebuilt the solenoid and my truck has a full GND cable to the engine block. But it would often, give me cause for concern sounding like it might not start, always at the worst possible moment. The parts to do the mod cost about $15: 30 A fuse holder-walmart Assorted pack of fuses- walmart 3ft length of 12 AWG copper stranded wire - Home Depot. crimpable end rings - Home Depot shrink tubing - already had some My only concern was that my soldering iron might not be up to the task. But it worked. The whole mod only took about 15 minutes. Even my son noticed the difference just hearing it start! Thanks, RAD4runner for driving this topic home. |
Originally Posted by Melrose 4r
(Post 52422300)
...doubting Thomas...
Link to Concise Description of Issue and Solution. |
(Post 52422300)
I was skeptical(doubting Thomas) - i already had rebuilt the solenoid and my truck has a full GND cable to the engine block. But it would often, give me cause for concern sounding like it might not start, always at the worst possible moment. The parts to do the mod cost about $15: 30 A fuse holder-walmart Assorted pack of fuses- walmart 3ft length of 12 AWG copper stranded wire - Home Depot. crimpable end rings - Home Depot shrink tubing - already had some My only concern was that my soldering iron might not be up to the task. But it worked. The whole mod only took about 15 minutes. Even my son noticed the difference just hearing it start! Thanks, RAD4runner for driving this topic home. while you are at it, do the headlight relay installation, too. if you haven’t, it’s only a matter of when not if the hi-beams will stop shining. |
Originally Posted by wallytoo
(Post 52422352)
(Post 52422354)
thanks, i wasn’t yet aware of that problem.
I also added relay to my horn circuit so it doesn't sound like that little guy with big ears from Anaheim, CA with his balls caught in a trap - LOL!
No need to tear into steering column contact because not that contact carries low current. HERE |
(Post 52422352)
... I snapped the stalk way before the contacts wore out :hillbill: |
Originally Posted by Co_94_PU
(Post 52422408)
Cost cutting engineering at its finest.. :
(Post 52422300)
My only concern was that my soldering iron might not be up to the task. But it worked. The whole mod only took about 15 minutes. Thanks to the parts list, Thomas! AND Re: soldering iron, My has been so useful when doing thick wires away from plastics or electronics, AND welding cracks on kayaks. Home Depot has the $20 version. |
Another vote for Ray's starter relay mod here. My truck had always done the click no start on those rare occasions, just enough to make it a pain but not really enough to root cause it. Fresh starter contacts didn't help, fresh battery didn't help. Then I did the starter relay mod and it never happened again. Been about 4 or 5 years. Good job Ray for figuring out the issue and informing people. Thanks for posting your results Thomas.
Thanks for the link to the 80w iron, Ray. I’ll have to get one of those. I don’t need more than 45 watts often, but when i do, i do!
(Post 52422441)
