Jagger's Build.
#41
Heh cup holders made me think of "trailer park boys", leave em clear put a couple novelty "fly in icecube" in and a little bit of epoxy to simulate whisky to complete the effect
Think i'd of gone with the modified chevy map pocket speaker covers even if they interfered with the seats folding over that. Recovering those panels is really easy hit the local craft store, 3m contact adhesive and material of your choice, and they'll look brand new again (sans' fancy molded lines).
Not sure on your 4runner, but in the 90's era trucks the paint code is also inside the D-side tail light. Incase someone paints over your ID placards.
#43
You could make your own CB whips out of them and have them to the exact size you want. Just gotta run wire coil-ing up it. Probably save a bunch too. My brothers whips were $60 each and hes got two.... Ya know what, im gunna make one! My little magnetic one flys off at over 40k. These things would be better then those fiberglass ones anyways. They can bend 180!
#44
Had a slow day today, kinda just putted along. Finished the wiring for the rear speakers. I just ran them up into the dash then back down under the door where that plastic door trim cover goes. Completely hides the wires!
Other then that i started a little clean up of the inside. It was really nice out today +15c so i was basically just enjoying the weather. Supposed to have another warm one tomorrow so i will bed line the floor so i can get my interior back together!
Tested my brake master out, it works!
I just plugged up the holes and pushed on the piston. No leak anywhere and i couldn't hear any air coming out. I still need to finding the fitting sizes for it! I will be posting up a separate thread for that to see if anyone knows, i can't find them anywhere!
Anyone know what usually causes E-brake binding? All my cables are in one piece it just wont pull... Could be one of them jammed. Hopefully i can fix it, id hate having to find a replacement. Had the idea of making a floor mounted one out of a little car ebrake, or even Hurst has one them make i think. If i had the money it'd be a transfer case brake for sure .
I just plugged up the holes and pushed on the piston. No leak anywhere and i couldn't hear any air coming out. I still need to finding the fitting sizes for it! I will be posting up a separate thread for that to see if anyone knows, i can't find them anywhere! Anyone know what usually causes E-brake binding? All my cables are in one piece it just wont pull... Could be one of them jammed. Hopefully i can fix it, id hate having to find a replacement. Had the idea of making a floor mounted one out of a little car ebrake, or even Hurst has one them make i think. If i had the money it'd be a transfer case brake for sure .
#46
Only picture update of the day. I used to build bobbers all the time, since i was 12, miss it like crazy, but insurance companies now charge out the ass for bike insurance, 6months was $4500... On my Gs400. So i had to sell most of the stuff i had. Found this today. Its a short mirror with a squish mount. I can't decide whether to buy another $15 because i have no stock mirrors and run these, or get stock replacements but have this one on the fender for when i run no doors... Decisions decisions.
You can see my sweet wrench ring in the mirror!
#47
Didn't do many things today, however i started putting some bedliner down. Got through one can and my second can was no good, wouldn't lay right... So ill have to buy another couple cans, i want it to be nice and thick to stop asmuch noise as possible. It looks wayyyy better then a grungy old carpet!
#49
technicaly that is a "Confederate navy jack", not to be confused with the Battle flag which is square.
Stars and bars is this one, and it's look a like (less stars)
There were lots of ex-confederate immigrations to the north
must be a flanking manuver.
#50
If you squint your eyes Jagger's license plate almost looks like it says "AWOL"... so you could be onto something
#51
#52
Tossed on a 31" tire i had sitting around to put in place of that flat tire. It's off of an 80's chevy. I was told the rim would fit a toyota, no sir. Wheel center is different... That rattles me up, as i have chevy rims awaiting to be put on it.... the 31 looks nice anyways. The rugged fender will be fixed soon no worries
Cut off those plastic bumper piece brackets, still fighting to get that trailer hitch off. Looks better now!
I got this isuzu grill for free from the scrap yard. It's not a direct fit, but i do like how it looks! ill have to move some things around but, this'll more then likely be the one i use. Kinda resembles a full size bronco front end.
#53
Well everyone following this thread, i'm moving it to the actual build up section i will be deleting this one if it's possible! Didn't realize there was a build up section when i joined.
LittleUgly
15
Jan 2, 2020 01:30 PM
nvwiggins
13
Jun 16, 2016 03:05 PM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
Toys4parts
Sep 26, 2015 01:56 PM
on the chimney sweep rod
