YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   intake difference... (https://www.yotatech.com/forums/f116/intake-difference-150364/)
stupid_mud_gremlins Jul 27, 2008 09:12 AM
I've got a buddy that's doing a 22re swap, what is the 4th intake vacuum line, I know the motor he is putting in was from an automatic, and his is a standard. I'm guessing that the fourth on the donor is for the auto tranny... Am I right in assuming that swapping the intakes is the easiest fix for this?
abecedarian Jul 27, 2008 09:26 AM
is it possible to get pics?
DeathCougar Jul 27, 2008 09:26 AM
The intakes between matching body styles of trucks is the exact same.
The throttle body can be different. Just follow the vacuum diagram under the hood on the sticker. Anything left over can be capped.
stupid_mud_gremlins Jul 27, 2008 10:33 AM
I'll try and get pics if I'm over there tonight. And as always, thanks to DC for the advice as well. I kinda thought it would be something like that from his description...I figured the whole intake might not be a bad idea as he has AC as well...
abecedarian Jul 27, 2008 10:41 AM
the intake shouldn't make a huge difference, if you change things over from the old manifold to the new. the a/c idle up switch is on the valve cover so that has to get moved over too.
