Instrument cluster not working on my 88 4runner
I have an 88 4runner with a 3.slow, and auto trans. The tach, oil and temp work, but the speedo, odometer, and fuel gauge do not. I know this gen has a problem with the speedo cable going out, which wuld cause the odometer not to work, but would that casue the fuel gauge to die? Is it an problem that I should replace the whole cluster and cable, cable only?
Any ideas? |
probably the fuel sending unit and the speedo cable, the circuits are all seperate in the speedometer head
Thanks. Does that mean if I replace the instrument panel it should fix the problem? Or do I need to replace the sending unit and the cable?
