Injector controller?
Old Oct 18, 2020 | 09:22 AM
Micmat's Avatar
Got a problem with one of the injectors on my 3vze, it’s constantly open. Wondering if the injectors are controlled by the ecu or a seperate controller?
Old Oct 18, 2020 | 11:14 AM
2ToyGuy's Avatar
You don't mention the year of your truck, and it matters.
Having said that, as far as I know, the ECU controls the injectors. BUT: A single injector remaining full open all the time sounds to ME, for what that's worth, that the injector is bad, not the controller.
Have you unplugged the electric connector to the injector in question, and checked to see if it's still wide open? That would tell the tale of whether it's the injector, or it's controller. If it remains wide open with the electric connector unplugged, it's the injector, no question.
Good luck, and keep us up to date
Pat☺
Old Oct 18, 2020 | 12:48 PM
wallytoo's Avatar
the injectors open at the same time. all six. so, if the other five are working, the issue is elsewhere.
Old Oct 18, 2020 | 10:48 PM
Micmat's Avatar
Pat☺
It is a 1994 4runner, i recently changed all the injectors for some i bought on ebay, can i check them by just blowing through them?
thanks for the reply! -mike
Old Oct 18, 2020 | 10:51 PM
Micmat's Avatar
alright but i just changed them all... can the problem be in the wiring? Do they actuate when they get a pulse of power or ground? Thanks fro the reply!
-mike
Old Oct 21, 2020 | 01:07 PM
Dr Phat's Avatar
Apply 12V to the one you suspect is stuck and see if it cycles open or closed.
I would not trust chinese eBay fuel injectors. OEM is a must for these trucks in this instance.
Old Oct 21, 2020 | 03:04 PM
thook's Avatar
^^^this!!!
i've looked at your other threads on this. not that i'm an expert by any stretch, but it occurred to me a problem in the wiring....like a short or something. ie. perhaps instead the voltage signal pulsing it's remaining a constant feed sans pulsing. just speculating
you've gotten really dynamite/expert input in other threads. give up the idea of the ECM/injector drivers.
mangos
Sep 29, 2020 09:28 AM
yogev
Oct 19, 2016 05:18 PM
longshot454
Sep 17, 2013 07:30 PM
suprathepeg
Aug 20, 2012 09:37 AM
ChaseHeadrick
9
Apr 10, 2005 07:14 AM
