The infamous 22re ticking question
Old Jul 25, 2012 | 06:51 PM
SPARKS89's Avatar
I think the other guys may be right about checking your valves. It makes sense that you wouldn't hear it any other time than when you're sitting still.
Old Jul 26, 2012 | 03:56 PM
cowboykid28's Avatar
Ok thanks.
Old Jul 26, 2012 | 04:02 PM
abecedarian's Avatar
I can't hear most of the noises my truck makes unless I'm sitting still. If I'm moving I hear the fan howling (sometimes), the exhaust and the stereo. Oh, and the wind leaking through my vent windows.
Which brings me to another noise posibility: the bearing on one of the idler pulleys- either a/c or power steering, or possibly even the alternator, water pump or fan clutch.
Old Jun 10, 2014 | 11:57 AM
ToyoBoyo269's Avatar
94 toyota p/u 4 cyl 22re Auto
HELP!
So I replaced all the belts, and tension may be a contributing factor but heres whats up:
Ticking/Rattle Noise (honest more like a Paint-Can Rattle) gets louder when A/C Compressor is turned on. Checked and noise is NOT coming from Compressor/Clutch. The noise seems to come from the Power Steering Pump-area. Fluid level is okay, but I did have a high pressure P/S hose leak and repair 3 years ago and it's been fine since the fix. So when the engine is under load its not getting louder, only when the A/C comressor kicks on does the noise in the P/S pump area increase.
Any help is much appreciated!
Old Jun 10, 2014 | 10:29 PM
  #25
Wow, Okay. I found the issue, and thankfully it was a classic case of "if you want it done right, do it yourself!"
I broke down far from home and had a unknown shop replace the Alternator. The rattle was their incompetence, as I noticed after more inspection that they didn't bolt down the alternator thru-bolt and nut. I rev-ed the TB and return to idle showed me how the Alt just seemed to move, just a little. Problem solved. Got underneath and torqued it down. I was really thinking that it was the PS pump, idler pulley bearing, or even the breakdown may have stressed the timing chain/guides.
Emergency averted.
coleypull15
Nov 3, 2015 07:41 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
cars-guy
Jul 11, 2015 07:51 PM
smiley52
Jul 11, 2015 05:16 AM
Gamble_STi
Jul 7, 2015 07:54 PM
