YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   Inertia Switch? (https://www.yotatech.com/forums/f116/inertia-switch-110231/)
Barker87 Mar 14, 2007 07:36 PM
Inertia Switch?
Does andybody know where the inertia switch for the fuel pump is on a 1995 4runner( 3.0 automatic)?
keithguts Mar 14, 2007 07:49 PM
I have the same rig, and would like to no more about this.
Barker87 Mar 14, 2007 07:56 PM
About the inertia switch?
keithguts Mar 14, 2007 08:00 PM
ya, the switch
chadbobb Mar 14, 2007 08:06 PM
what is an inertia switch?
Barker87 Mar 14, 2007 08:20 PM
It's a switch that activitates after you are in a collision and it shuts off your fuel pump so that your vehicle doesnt explode
^VooDoo^ Mar 14, 2007 08:36 PM
3vz and 22re dont have them.
They used a fuse that just covers the power needs of the system, Anymore of a spike and it pops the fuse.
Also the AFM is the only other safety device, It shuts the fuelpump off if the engine dies.
(If you flip over the fuel pickup will cavatate and kill the engine but Ive wonder what happens if you just land on the side with a full tank, Theres nothing to stop the engine till it oilstarves and freezes)
Barker87 Mar 14, 2007 08:38 PM
are you sure?!
notanymore Mar 14, 2007 08:39 PM
i thought the inertia switch was just for airbags? guess you learn new things every day
deserttoy84 Mar 14, 2007 08:43 PM
Come on now.... we own toyotas not fords. I know all about ford rangers and inertia switches LOL. they randomly tripped somtimes even when your not moving. just oen more reason to no like ford trucks
marko3xl3 Mar 14, 2007 08:46 PM
I know for a fact that airbags use a deceleration sensor (I guess you can call that inertia). But I thought that the whole fuel pump shebang is controlled by the airbag ECU once it itself trips the airbags if Toyotas even have the fuel cutoff feature. I wouldn't know for sure...
Barker87 Mar 14, 2007 08:54 PM
Ok so there is no inertia switch, are you 100% sure?
DeathCougar Mar 14, 2007 09:18 PM
There is no Inertia switch in a Toyota.
It relys on input from the airflow meter in some cases, crank sensor in other cases (late model) You can turn the engine to on, without starting it, and fuel will not be pumping. If you dont believe that, for those of you with cold start injectors...turn the Ignition to on (dont start it) and crack open the 12mm banjo bolt leading to the injector. Fuel will come out, but it will not continusly spray. If you leave it cracked open and turn the engine over, fuel will spray out of there.
btw, thats also a good quick/cheap trick for checking to be sure the fuel pump is working.
Barker87 Mar 14, 2007 10:09 PM
Ok so I'm still screwed well I guess I'll see what that guy with the diagnostics says, thanks
Morgan Feemster Feb 12, 2018 08:21 PM
Dose any one know if a 2007 fj has an inertia switch not getting any power to the fuel pump Brand new fuel pump and relay btw
akwheeler Feb 13, 2018 07:13 AM
Find a wiring diagram and troubleshoot with a test light or multi meter. A wiring diagram for your vehicle will show if there is an inertia switch (I'm 99% sure it won't as stated above this is more of a Ford thing and not just their pickups) and without the diagram you are flying blind, check the fuse first.
