IFS upgrades
Old Feb 13, 2008 | 04:53 PM
yotaman85's Avatar
so can i get stronger shafts for the front. i know downey has some but only in extended langths
Old Feb 13, 2008 | 05:31 PM
JonnyBoy's Avatar
If you're going to SAS later, it really wouldn't be worth the money to get stronger cv's. They'd be custom I'm pretty sure, and custom usually means $
They're saying stronger cv's aren't needed, and I'd agree. I wheeled mine for a couple months with torn boots, almost totally dry joints, and they were clicking while turning either way. I still kept one for a spare, though I don't plan to need it.
Fix the steering weaknesses, and you're pretty much set!
Old Feb 13, 2008 | 05:51 PM
AxleIke's Avatar
You can get Porsche joints. They are spendy. On a CV, the joints are the weak part, the shafts seldom break. TC managed it, but I have a feeling that was old crap stuck in there from a previous issue.
Old Feb 13, 2008 | 06:07 PM
yotaman85's Avatar
what are the best steering upgrades and were can i get them
Old Feb 13, 2008 | 06:56 PM
  #25
nate V's Avatar
Originally Posted by AxleIke
Unless you rock crawl, your shafts will hold up to 35's pretty well. Don't drive it like an idiot, and they'll be just fine. Avoid cranking full lock right or left and then punching the gas, and avoid spinning the tires really fast and then letting them hit the ground. If you raise a tire, let off the gas, and try a different line.
Carry spares, do the stud mod, and practice changing them once in the driveway. Troy and I together can do one pretty damn quick. Unless troy's skid plate gets cranky. Then I spend a few minutes cussing. But still. Pretty quick.
Sorry but what is a stud mod??????????????
Old Feb 13, 2008 | 06:59 PM
  #26
4Crawler's Avatar
See:
http://toyota.off-road.com/toyota/Ch...tegoryId=10824
Old Feb 13, 2008 | 07:06 PM
  #27
AxleIke's Avatar
What he said.
Old Feb 13, 2008 | 07:09 PM
  #28
Tacoclimber's Avatar
The stud mod is what I do every time I get behind the wheel....
(Sorry, couldn't resist)
Old Feb 13, 2008 | 07:10 PM
  #29
AxleIke's Avatar
You're entitled.
I was in a hurry and should have explained more.
Old Feb 13, 2008 | 08:13 PM
  #30
norcalsvx's Avatar
I wheel pretty hard in my IFS , lockers and gears would be where i would spend my $$ and some nice tires as well my mods list is below
Old Feb 13, 2008 | 09:09 PM
  #31
EWAYota's Avatar
Originally Posted by 4Crawler
I clicked on that link but the article wasn't there anymore
Old Feb 14, 2008 | 05:45 AM
  #32
nate V's Avatar
where did it go.....?
Old Feb 14, 2008 | 09:06 AM
  #33
tc's Avatar
tc
Basically, the stud mod is to knock out the pressed in studs and replace them with bolts. Being able to get the bolts out of the way makes it MUCH easier to get the CV out.
I broke a shaft with the front (only) locked, in compound low, on the throttle, on rock. In other words, I was sending approx 36,000 ft-lbs of torque to the one axle. Not exactly unsurprising that it broke...
Old Feb 14, 2008 | 09:20 AM
  #34
Brenjen's Avatar
I tried to show someone that page a month ago & it wasn't up. I'm wondering if they know or care that it's blank.
The other way is to pound out the studs & grind off the locking ridges, then you don't have to buy new hardware.
Old Feb 14, 2008 | 09:37 AM
  #35
Is there a standard size bolt to use when doing this? I searched all over YT and TTORA and can't find the bolt size. I'd like to do this, but I'd like to have the hardware ahead of time...
(Now, if one of you guys goes and finds a thread with that info in it, I'm gonna flip...)
Old Feb 14, 2008 | 10:55 AM
  #36
AxleIke's Avatar
CJ, I don't know how this works on Third gens. Unless, you have a first or second gen we don't know about
Old Feb 14, 2008 | 11:02 AM
  #37
Yeah, I wish... If I did, it would look like yours...
Oh well, looks like I'll have to guinea pig it. When I do it, I'll make sure to post up for posterity's sake.
Old Feb 15, 2008 | 02:32 PM
  #38
tc's Avatar
tc
Third gens use the clamshell diff where the CV is splined and goes straight into the diff - there are no bolts.
The bolt size is M12-1.25x30mm - same as used on the brake calipers, crossmembers, diff/body mount, and a few other places - buy plenty to have as spares.
Old Feb 15, 2008 | 09:21 PM
  #39
yotaman85's Avatar
are they stronger then the bolt style
Old Feb 16, 2008 | 08:02 AM
  #40
tc's Avatar
tc
I don't know, but it doesn't matter, they're not interchangeable.
The clamshell diff is high pinion, so the R&P should be ~30% stronger.
