YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   idle problem with 22re (https://www.yotatech.com/forums/f116/idle-problem-22re-168082/)
kawasakimoto_7 Feb 25, 2009 09:18 AM
alright well i have a problem with my 22re (206,600 miles) whenever im sitting at a light or something my truck sits a rattles everything in the truck...like a lot but once i get going it stops or when i have my foot on the gas a little it stops too...what could the problem be?
-thanks
abecedarian Feb 25, 2009 09:30 AM
checked your spark plugs, distributor cap, wires and coil?
how are your engine mounts?
kawasakimoto_7 Feb 25, 2009 09:33 AM
the engine mounts are good and everything but i guess it might be the plugs and whatnot cause i sunk my engine underwater like a month or two ago...so i should probally pull and clean those or something.
Kiroshu Feb 25, 2009 11:10 AM
Uh yea!
chris1rb Feb 25, 2009 11:19 AM
i have the same problem and replaced everything u listed, my uncle is a mechanic and has his own shop, www.rosevillerodandcustom.com but anyways he went over it and the 4th cylinder on mine is running rich and he thinks the injector is bad and i have a really rough idle but once u give it power it smooths out so sounds like an injector
toyota4x4907 Feb 25, 2009 11:23 AM
Try upping the idle just a smidgen, that might temporarily fix it if it bothers you.
replace the air filter as well.
kawasakimoto_7 Feb 25, 2009 12:13 PM
yeah im going to go through and probally change everything cause my truck is starting to overheat too but thats probally radiator fluid that i need to change
abecedarian Feb 25, 2009 01:28 PM
if you're low on coolant, that can affect the idle quality on a 22re. also, thermostat rating should be 195.
...just a thought.
