Idle lower after adjusting alt and PS belts
so belts replaced awhile back, started having some squeal. Alt and PS had about an inch of flex. Tightened them to between 1/4 and 1/2 inch. No squeal. Did this yesterday. This morning 45 degrees outside, it kept wanting to die while I was trying to start it. Driveway is a hill and I couldn't get my foot from th le brake to the gas fast enough to keep her going. Usually cranks right up, and idle was about 500. Once it got going, the idle was well below 500, maybe 250-300. They don't seem too tight. Is it normal to have an idle drop some after drive belt replacement or adjustment especially considering it was low to start with?
500 rpm idle is way too low for a 22re. Factory setting is 850 rpm. Try loosening the idle adjust screw on the top of the tb. If that doesn't work, you've probably got a vacuum leak somewhere. Check all hose connections and especially the large accordian-like molded hose right in front of the tb, they're notorious for tears along the ribs after a few decades.
Belts don't have to be real tight on these engines, mine are kinda loose (3/4" deflection with a gentle push)) and I've never noticed them slipping. With your idle so low, that extra drag from too tight belts is causing the engine to bog and stall. |
Thanks GSP. I just checked everything around where I was working to make sure I didn't break the "accordion" like piece u mentioned. I did unsnap the airbox like u would to change the filter and move it back when I was trying to get to the alternator belt adjustment. But I only moved it as much as u would to change the filter. No cracks or tears. Setting at a stoplight, it idles at about 300 w AC off. On it kicks up 500-600 RPM. THinking back, I'm not sure if the idle has changed at all. I KNOW it was never over 700. Tightening thise belts may have been just enough to make it drag on start before I can get my foot on the gas pedal. Soon as I get a chance, I will back them off a bit and adjust the idle.
The a/c has an idle-up adjustment itself off the side of the intake plenum. It's a white screw with a spring under it. It's normal for the idle to be higher with a/c on because the compressor is more efficient at higher rpm.
It has always cranked right up. The idle has also always been low but with no problems, why mess with it. I work in the sciences... never change more than one variable at a time. ALL I did yesterday was tighten the alt belt and PS belt and they are not banjo tight. Quarter to a half inch now. I also bought gas, but that was at the place I've been buying gas from for 15 yrs without a problem. Would the really low idle then the extra drag of tighter belts really make it not want to take off and run on start up? Guess it would. Once heading down the road, runs like a scalded ape. Not missing, nothing.
You're right about the single-variable problem solving, but I'm just trying to help you out with what I've learned about these engines over the past couple years of tinkering with them.
The 22re is designed to idle at 850 rpm for optimal performance and a lot of owners find benefit in adjusting it even higher, though the ecu is programed for a fuel cut over 1000 rpm with the butterfly valve fully closed. Using your scientific method, if I were you, I'd adjust the belts back to 1/2" - 3/4" deflection and start your troubleshooting over. If something's squealing up front, it could be the a/c or p/s tension pulley. They're known to howl, groan or even squeal when worn. Tightening the belts might quiet those sounds down for awhile, but isn't fixing the problem, just covering a symptom. The p/s pulley bearing is replaceable while the a/c pulley has a captive bearing and must be replaced entirely. I've done both recently along with a new fan clutch and it's just amazing how much quieter things are in there now. Pop the hood with the engine running and manually open the throttle for a better sense of what's squealing and from where. |
Originally Posted by gsp4life
(Post 52383934)
You're right about the single-variable problem solving, but I'm just trying to help you out with what I've learned about these engines over the past couple years of tinkering with them .
Thanks for your help GSP. Idle adjusted up, belts loosened a bit. Good starts, idle and no squeals.
:great:
Glad to hear it was something that simple. |
