YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   ide screw... (https://www.yotatech.com/forums/f116/ide-screw-154941/)
toyotarunner92 Sep 19, 2008 08:38 AM
ide screw...
i cannot find the idle screw... i have a rough idle around 300 -400 rpms when the engine is warmed up... if you know where this is let me know
Jay351 Sep 19, 2008 01:12 PM
Open the hood. Look directly at the throttle body. You will see a flat screw that uses a flathead screwdriver.. Its flush with the throttle body so its easy to miss...
fillsrunner4 Sep 19, 2008 01:58 PM
what a misleading tittle :lof:
TNRabbit Sep 22, 2008 02:07 AM
I forget, is SIX or SEVEN million times this question has been asked?? I believe it's SLIGHTLY behind "Can I crank up my torsion bars?"....
:hillbill: :hillbill: :hillbill: :hillbill:
Myron Sep 22, 2008 03:11 AM
search is your best friend.
https://www.yotatech.com/forums/f116...-valve-152784/
there are some pics in there
so next time..try it out
Jay351 Sep 22, 2008 03:11 PM
I actually had to look in the FSM for that little bastard :(
Myron Sep 22, 2008 04:20 PM
haha took me a few times till i found mine.
