I need some news ideas on a unique missfire.
#61
#63
CRAAAAP, this reminded my of a symptom I completely forgot to mention, or even think about.. Often times when I burp the throttle, I can hear the AFM buffeting.
Can't believe I forgot that.
Damnit..
I've never witnessed a sticking valve before. It's starting to really sound like that might be it.
Damnit..
#65
That's when it's most noticeable, when you quickly hit the gas it makes a popping noise in the intake. But, don't get that confused with an ignition misfire, it sounds louder with a sticky valve. I'd take it somewhere to get hooked up to a scope to make sure it's not an ignition misfire before you pull the head .
Like the intake valve is sticking and pulsing pressure into the intake manifold.
#66
Did you check your vf signal yet? That will tell you if it's running lean or rich. Heres the writeup, http://www.well.com/user/mosk/Vfsignal.htm
#67
That's a good write up, and no I haven't verified the mixture quantitatively like that, I have however forced mixture changes by increasing fuel rail pressue and manual swinging the AFM about while idling. Engine rpm responded as expected, but still never fired on number one.
#69
Problem found!!
Yep, sticking intake valve. Check it out. Didn't happen this time, but I could hear the intake screech a couple times as it closed.
#74
Lot of carbon build up after lots of miles I would imagine, or something along those lines.
But this obviously isn't the case here as the head has less than 700miles.
It's gotta be a manufacturing defect. I mean the valve literally screeches.
I'll be placing a call to Ted tomorrow.
#78
Thanks all
Thanks everyone for the suggestions, I'm not sure how long it would have taken before I figured out the sticking valve. Although it seems so obvious now, guess that's always the case.
Glad to have it figured finally, been dumping countless hours into this since the head was put on.
Thanks again!
Thanks again!
#79
Wow, after dumping that money into a new head, new gaskets and such that suuuuuuucks!
I wonder how much of that they'll cover, probably just the head if it was assembled when they got it. If they did the machining and installed the valves I would hope they would cover a little more than that, maybe give you a head gasket?
Did you get the Pro-Topline head or their OEM Replacement?
#80
nice work man
Awesome, we have evidence and an answer. I figured it had to be an obscure management issue or a mechanical problem.
Sometimes you gotta reproduce the problem conditions completely before you get answers. Again, good work man.
