i need help
i just bought this truck (87 pickup 4x4) this is my summer project
i need advice on what to do to get it trail ready i know i need bigger tires and apparently a straight axle in front any sugestions truck is stock everything |
Things to Search
-SAS or Solid front axle swap -Gears -Dual transfer case -chevy leaf swap or 4 link suspension - not sure on what kind of tires but id say 33X12.5's or bigger -4 inch lift or a tad bigger Your going for flex and low gears so you can crawl instead of flail driving wich usually leads to flopping |
flex im up in washington about 30 min from tahuya
i went out there today and just about flopped |
Originally Posted by im_on_fire4278
(Post 50839419)
i went out there today and just about flopped So you think lifting the truck and putting bigger tires will help keep it from flopping? Learn to drive the truck first STOCK offroad.....then modify the truck as fit for your needs. |
