HUB: Normal or replace??
1990 T4r w/ auto, 4x4, 3ZVE
I posted a thread within past few days regarding my 4 runnier; 'rubbing followed by a clunk" . Initialing found a tear in the passenger side CV boot. I removed and purchased a new replacement. I did not notice any scaring or damage to the old unit. When I removed the front hub, rotor, and brake assembly and at the rear of the hub there is what appears to be a brass bushing and my first impression was that it is severely damaged and scarred with grooves on the face and down the sides of the bearing;/bushing, I have never had to replace the bearing/bushings so not clear what to expect. Appears there is a roller bearing to support the spline at the front but I am unclear what is supporting the spline at the rear of the hub. Posting couple pic's in the hopes member(s) can provide some suggestions and/or advice. Further, if the hub is okay but the bushings need to be replaced does it a DIY or require special tools. I want to get the vehicle back on the road and either order replacement parts or take to shop and have the necessary work done. Any suggestions and comments appreciated!! https://cimg8.ibsrv.net/gimg/www.yot...d768b6e257.jpg https://cimg9.ibsrv.net/gimg/www.yot...f57e28e90f.jpg https://cimg2.ibsrv.net/gimg/www.yot...2af1b6b780.jpg https://cimg7.ibsrv.net/gimg/www.yot...a887197b18.jpg https://cimg2.ibsrv.net/gimg/www.yot...fbaf1ebdd7.jpg I have replaced bearings in other vehicles in the past which usually consist of using a brass punch to remove the front and rear wheel bearings |
That's not normal wear on back of that hub. I've never replaced one either, but I suspect you'll need a press to get it out. You might be better off just getting a new hub assembly, or good used one.
There is nothing wrong with the bushings in that hub
Originally Posted by millball
(Post 52460246)
Originally Posted by jsabowabo
(Post 52460243)
Appreciate the input!! |
| All times are GMT -8. The time now is 06:02 AM. |
