How much does a 2.7 or 3.4 swap cost?
I have been weighing some options recently and would like to know how much a 2.7 or a 3.4 cost on average? Next question is it worth it? Which one gives you the best bag for your buck? How hard are they to do?
Depends on plenty of things. What engine do you have currently? I'd guess 22r(e) since you're considering the 2.7. What transmission do you have? Do you have good wrecking yards or a good Craigslist or some other classifieds in your area? I'm assuming so, since you're location says Sac. What are your performance goals? Have you happened to check the 3.4 swap section on here? Yotatech.com/f160.
Dunno how relevant my info would be, but here's about my list of costs Engine+trans $1000 Sold 3.0 -$300 or so ORS harness and kit pieces $1059 or something like that Toyonlyswaps crossover manifold $150 Marlin crawler clutch kit $350 Never sold the trans, used the 3.0 trans and last I heard my sister scrapped the 3.4 r150 I had setting at my parents' where I did the swap. Also, if you don't have the tools already, there's rental of a hoist and stand, jack and stands probably, and the cost of whatever fluids and maintenance parts you get. I got an engine in great shape, minus the timing belt was slightly overdue and the power steering pump that came with it was shot. That's all I can think of off the top of my head, so you should check out the swap section, toyonlyswaps.com, and even offroadsolutions.com still has info up on their website, at least. Was it worth it? Heck yes! I didn't even have as much a problem as some did with the 3.0, but it's still made the drivability tons better. A particular grade outside of Eugene, OR on hwy 58 used to see me going down to 3rd and floored to keep 60 with nearly nothing in the rig. With the 3.4 and loaded to the gills when I moved down here for work, I was able to go up the same hill in 4th and probably 2/3 throttle to keep 60. No gear or tire changes from 3.0 to 3.4. |
:con::con: Are you talking doing all the labor your self or having it done??
Now from start to finish paying for labor and the vehicle to do the swap I have around $12,000 is it worth it . Well to me it was much better then spending the money redoing the kitchen!!:con::con: Buy a complete vehicle with a good running 3.4 the correct ecu if it does not match yours manual/auto a new wire harness for the 3.4 . Depending on your skills the integration of the two wiring harnesses could be the hardest part. Now I have all the parts to do a 7MGTE Swap but I like the 3.4 so much better I just may go that way.:con: |
:eeek: am i reading that right you spent 12k on your 3.4 swap gotta hand to you your dedicated.
im trying to get mine done for under $2500 i got lucky thought picked up a 3.4 with all the goodies for $1000 bucks. and im gonna be doing all the labor myself though so that will save me a heap of cash. citrusthedragon ive heard sacramento has a some of the best toyota truck dismantlers in cali so your in a good location to get the parts for either swap. all toyota truck and suv parts, and rancho toyota truck parts are a couple ive heard of i think there's more too but im not sure. however if your looking to save some cash try to find one at pick and pull they don't know what they've got so you may get a better deal. |
Originally Posted by JonnyBoy
(Post 52022536)
What engine do you have currently? What transmission do you have? Do you have good wrecking yards or a good Craigslist or some other classifieds in your area? What are your performance goals?
Originally Posted by wyoming9
(Post 52022537)
Originally Posted by 2toys
(Post 52022589)
that figure is the Total cost of everything from start to finish starting with nothing.
Plus 4 new tires , All new shocks, sway bar bushings and links, New battery it adds up fast:welder: |
Just a rule of thumb for an engine swap. Put a number out there on what you think it will cost and budget twice that. I know it sounds stupid, but there are lots of unknowns in a swap and its nice to be able to cover it. Trust me haha.
Search. There is a 3.4 forum full of info on the 3.4 swaps.
I can do them myself and including the project vehicle, donor vehicle, parts etc NOT counting labor you won't get there for under $5k and have anything worth a ˟˟˟˟. :wabbit2: |
Originally Posted by CitrusTheDragon
(Post 52022660)
I'm hoping to get a pretty good deal too by buying a full T100 whether it's the 2.7 or 3.4. I'm using other parts on the truck for different upgrades and projects.
I spent about $4-5K on my 2.7 swap. And I did all the install labor myself. I had the machine shop do engine disassembly and reassembly, but I removed all accesories, and reinstalled everything. With the cost of LCE Perf. master rebuild kit, machine work expense, cost of engine/bellhousing/wiring harness from the wrecking yard, all new clutch (Marlin), alternator, radiator, Chilkat mounts, FSM wiring books, etc.... It adds up very fast.
we do the 3.4L "turn key" swap for 5K ...
(Post 52022715)
ya having the donor vehicle is the way to go for sure. how come ur thinkin the 3.4 is too heavy? doesn't weight anymore than a 3.0 does.
Originally Posted by slacker
(Post 52022751)
I'm currentlyy doing my 3.4 swap
1100 for motor and everything from the doner vehicle 450 for electrical stuff manual ecu and wiring labor Made my own crossover Clutch flywheel cost me about 250 with a discount Probably have 200 in random stuff |
I have to brag I have about $1600 in mine from including the cost of the vehicle, tires, and locker. Get a complete doner, then part it out when you're done, then scrap it. It was a lot of work, headache, researching, and head scratching. There are a few of us that have done it ultra low budget, and it always includes a complete doner.
Originally Posted by vasinvictor
(Post 52022868)
Has anyone done a 2.7 swap?
Rokblok, JustDSM, BigMike from Marlin, and the RA Designs guy(cant quite remember his username on here right now) are the guys that I can think of off the top of my head.
Why can't I find their write ups on here. I think my phone doesn't search right on the mobile site
| All times are GMT -8. The time now is 09:12 PM. |
