YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   How much ATF? (https://www.yotatech.com/forums/f116/how-much-atf-305898/)
Cumminsguy1 Oct 9, 2018 04:33 AM
How much ATF?
So I dropped my trans pan on my 86 auto pickup to replace the TC solenoid and I cant find a clear answer as everything I've read says to add 3-7qts of atf.... I kind of need an answer alittle more specific as I ONLY DROPED THE PAN but searching through previous threads I just see people arguing and not any kind of helpful info on an exact answer I just bought this truck and it came without a dipstick so I'm SOL there
Co_94_PU Oct 9, 2018 06:37 AM
Well first off get a dipstick...
Call Jim at "yota Jim's", or Nancy at "yota yard". Both are located in Denver, CO.
The answer between seven and three quarts is probably accurate, I don't have the 86 service manual, start with how ever much made it into your drain and catch pan then you'll need to maybe add abit for what's on the floor and other places..
The 1988 FSM says...
​​​​​​​https://cimg6.ibsrv.net/gimg/www.yot...b75bdc3823.png
Cumminsguy1 Oct 9, 2018 10:03 AM
Alright I got in touch with "yota Jim's" and "yota yard" both places said they really did not know how much to tell me.... I'll just try to measure how much came out like you said, just worried that it may have been low in the first place because I dont know when it was last serviced
millball Oct 9, 2018 11:46 AM
Maybe you're a little slow???? Co_94_PU was suggesting that you buy a dipstick from them.....
Cumminsguy1 Oct 9, 2018 05:16 PM
misread that my bad. I ordered one last week and should be here Monday i was hoping I would have the truck running before then
Cumminsguy1 Oct 9, 2018 05:37 PM
Co_94_PU Oct 10, 2018 04:31 AM
In your other thread when I asked if you checked the transmission fluid, you said something along the lines of "yeah just did last week". That's really hard to do with out a stick of the appropriate length. You might have just done all this for nothing, mine acts just like you described when it's low on fluid..
Just saying...
