How to jack the rear up...?
I just put in a 3inch body lift and the ass-end is still saggin like it did before. Is there anyway I can level it up with the front?
thanks for the input |
4Runner or truck?
4Runner - coil spring spacer or new springs truck - add a leaf or new spring pack either - lower the tbars in the front ... and sorry, but if you put on a body lift to fix suspension sag, you ain't exactly the brightest bulb in the box now are ya? ... |
what kind of vehicle?
would'nt longer shackles work too if its a leaf spring suspension??
Originally Posted by Plumbrbob
(Post 51057727)
Remember, however longer a shackle is than the stock shackle, the lift acheived is only goning to be half that length. For instance, I have WabFab shackles on my 91 PU that are 3.5" longer than stock, so that nets me 1.75" of lift. Well, it would if my rear springs weren't saggin like an old ladies... nevermind... On that note, stupidly long shackels are not a good thing. The longer they get, the more flimsy they tend to get, so keep that in mind... |
Originally Posted by iamsuperbleeder
(Post 51057741)
On that note, stupidly long shackels are not a good thing. The longer they get, the more flimsy they tend to get, so keep that in mind... I am running TG 6" shackles on 4" TG springs I have no problems with them at that length. |
Originally Posted by tc
(Post 51057699)
4Runner or truck?
4Runner - coil spring spacer or new springs truck - add a leaf or new spring pack either - lower the tbars in the front ZUK mod. |
if you have a 2nd gen 4runner on coils i will have some up for sale in early march for $100 that will fix the sag
here is the link: https://www.yotatech.com/forums/f11/...y-butt-165239/ |
(Post 51057747)
I have seen some super long home made shackles they look craZy!
I am running TG 6" shackles on 4" TG springs I have no problems with them at that length. http://i113.photobucket.com/albums/n...e/shackles.jpg |
the op seriously thought a body lift would cure a saggin arse? wow now ive seen it all
heres an ideal, cut the front body lift pucks in half and the middle ones at 75%, and walla its level |
how about a suspension lift?
but really tho...add a leaf, coil spacers, new coils, etc....really all depends on what you drive...need more info did you install the bl to fix the sag, or was it just for overall lift |
always drive downhill.
smaller tires up front / larger tires out back. |
somewhere on here, maybe in the repairs or tech section, there is a good homie here , who shows how to fix this prob, with an extra leaf, at home, with pics included. Such good peeps!!!!
just buy new lift springs, either leaf or coil what ever you have.
Wow, first post and im getting accused of being some sort of retard...
I knew before that the body lift would not fix the sag. I just wanted to mention that I just put a body lift and that my next step was to work on leveling it up a bit. BTW its a 2nd gen 4runner |
Originally Posted by quadrider32
(Post 51057698)
Anyway Coil spacers or coil springs will bring your runners butt back up. Super easy to install inexpensive to purchase Try SDORI spacers These seem to be very popular!! |
Trying to refrain from making a smartass comment here...if you were a buddy in my garage, I'd be laughing pretty hard at you right now. But you question seems genuine, so I'll hold my tongue.
I'm assuming a 4runner. The rear sags because the leaf springs are the same ones the used for the trucks. They didn't account for the several-hundred pounds of extra weight added by the 4runner and the impact it'd have on the leafs. So the ass sags. I've not seen a first gen that doesn't and quite a few 2nd gens that do as well. A body lift does nothing to fix the problem...just gets the body higher in the air. Solution. Add a leaf or just replace the stocks with new. Adding a leaf is cheaper (not entirely easier) but still doesn't completely address the over-compressing of the stocks. Still, either will get the rear up. |
Originally Posted by chewie1014
(Post 51058078)
I'm assuming a 4runner. The rear sags because the leaf springs are the same ones the used for the trucks. They didn't account for the several-hundred pounds of extra weight added by the 4runner and the impact it'd have on the leafs. So the ass sags. I've not seen a first gen that doesn't and quite a few 2nd gens that do as well. A body lift does nothing to fix the problem...just gets the body higher in the air. Solution. Add a leaf or just replace the stocks with new. Adding a leaf is cheaper (not entirely easier) but still doesn't completely address the over-compressing of the stocks. Still, either will get the rear up. Thanks for the help man but I did know the body lift would not have helped the sag. As said before, I worded it wrong. I dont wanna come across as some unintelligble contributor to this website. |
(Post 51058091)
New coils is what you need. It'll also help it ride a LOT smoother. It's also okay to be unintelligble on some things. That's how we learn. Some folks don't realize that and are pretty harsh on any person that has an honest question they think is stupid. I can do without them. But for the most part, people here are just picking when they fire back with a zinger. Not all, but most. Welcome to the forum. Now that you've been properly initiated, feel free to fire back. |
