Hose number?
1986 Toyota 22R, what number hose runs just above the oil filter from the nipple on the bottom of the intake manifold to the pipe that goes into the timing cover just behind the water pump? It looks to have two different sized ends. Thanks!
:coffee:
I am pretty sure I know what hose you are talking about. Below is the OEM Toyota part name and number. Check to see if this is the same hose you are wanting to replace. HOSE, WATER BY-PASS 16261-35061 https://cimg2.ibsrv.net/gimg/www.yot...4e0e26fece.jpg https://cimg1.ibsrv.net/gimg/www.yot...63585edd96.jpg This hose is still available from Toyota from your local dealership or here: https://www.toyotapartsdeal.com/oem/...261-35061.html :safari: |
