Hi-Lift Mount to yakima bars
I've got a 2nd gen runner with a set of yakima bars and the cheap basket case roof rack. I'd like to mount my 48" hi-lift directly to the yakima cross bars, not the basket. I've got the stock bumpers for now, so that rules out mounting the jack to them. Does anyone make a set of mounts to mount directly to the bars? I searched and found that slee offroad used to make one, but i couldn't find it on their website. I'm pretty close to fabbing a set, but if someone knows where i can find them online, give me a shout.
Any other ideas on where I could mount my jack? |
Yes, look on my website in my sig, and also look in the Tech section for my article.
https://www.yotatech.com/~corey/tech/techpage.htm https://www.yotatech.com/~corey/tech...mods/corey.htm Hi Lift mounted to Yakima cross bars via Slee's mounts. |
Thanks Corey, but it appears that slee no longer carries that bracket. Please correct me if i'm wrong.
Corey,
http://www.sleeoffroad.com/products/...fracks_acc.htm Part #:SOF1004 is that the right part number? It threw me off because it says that those brackets are for the stock toyota bars.....but i didn't read the fine print. |
Either of these:
Hi-Lift Mount With Mighty Mounts Part #:SOF1005 - $60.00 Hi-Lift Without Mighty Mounts Part #:SOF1004 - $39.00 All the Mighty Mounts are is the round clamps that mount the units to the cross bars. You can also ge them at any store that carries Yak stuff, and REI. |
i checked REI - $8 for a pack of 4.
Thanks again! |
