YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   help size bolts to use on a rotor cap on 1988 toyota v6 (https://www.yotatech.com/forums/f116/help-size-bolts-use-rotor-cap-1988-toyota-v6-303715/)
Larry H 03-11-2018 07:58 AM
Can anyone tell me what size bolts to use on a rotor cap . After engine rebuild on 1988 toyota v6 , the bolts hold down rotor cap were misplaced.
muddpigg 03-11-2018 08:19 AM
And Google says https://www.yotatech.com/forums/f116...r-bolt-222758/
M8X1.25 is a good starting place. Toyota makes life easy by using same part on multiple engines/vehicles plus makes logistics of parts easier for manufacturer.
millball 03-11-2018 01:46 PM
What's a rotor cap???
Got a pic??
scope103 03-11-2018 09:57 PM
He probably means the two small machine screws that hold the distributor cap to the distributor body (but given the vocabulary issues, a picture could clear that up). Probably M4 or M3, but you'd need to buy one of each and try them.
wyoming9 03-12-2018 01:00 AM
M5 if I remember
