YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   Help replacing the window regulator? (https://www.yotatech.com/forums/f116/help-replacing-window-regulator-252348/)
khanman47 Apr 16, 2012 09:46 AM
Well I've gotten the door panel off to the metal frame, does anyone have a diagram or a DIY bookmark so I can fix this window regulator?
BMcEL Apr 16, 2012 11:24 AM
http://ncttora.com/fsm/
Rowland Apr 16, 2012 11:46 AM
https://www.yotatech.com/forums/f116...cement-123524/
https://www.yotatech.com/forums/f116...y-week-152097/
https://www.yotatech.com/forums/f116...oblems-157499/
Utah4Runner86 Apr 18, 2012 02:29 AM
This is really not that tricky :think: - roll the window down until you can see the two bolts holding the regulator arm to the window. Duct tape the window there and remove them. Now remove the three bolts holding the regulator to the door. Remove the regulator. Reverse the process to install.
