Help with power windows and locks
I have a 94 extended cap v6 pickup that had the manual windows and lock doors, it now has power doors, I need to know how to make them,work for as wiring them up? Any help would be greatly appreciated!!! Thanks
A problem well-stated is almost solved. A picture paints a thousand words.
You have to put us in front of your truck. What door did you get? What model-year-engine-transmission-trim was the donor truck? What came with your door? Post clear pictures of your fuse blocks so people will see if your truck already has components (fuses, circuit breaker, relays) necessary to run a power door. Does your truck have places for switches to control door? How did you run the wires between the body and the door? What wires do you have in there? What switches does the new door have? Post clear pictures of the switches and wires. |
I assume you had factory manual doors, and managed to pick up a pair of doors with power windows/locks. The good news is you have the necessary switches and motors. But you're going to need to find a door lock control relay (size of a pack of cigarettes, above your left knee). http://web.archive.org/web/201106261.../8powerdoo.pdf They're still available, but you won't like the price of a new one. https://parts.lakelandtoyota.com/p/T...598035030.html
You'll also need the connector and wiring from the door to the relay; I'm guessing your doors were removed with wire cutters. You might be able find a salvage relay that was also removed with wire cutters, so you'll have the connector body. |
Here is where prior planning comes into play .
Instead of a simple job now it will be so very interesting . I would plan on getting the Toyota Electrical Wiring Diagrams for your truck Or Lots of Fuses Fire Extinguisher Local Fire Company on Speed dial |
| All times are GMT -8. The time now is 05:59 AM. |
