Help my radio stopped working
Hello!
My radio stopped working, it is after market and has a sub. the speakers have nothing coming out but the sub is still working. I'm leaving on a 750 mile journey in 3 days and I need to fix it because I need my jams! thoughts? I checked the wiring and all looks good there. |
I think your bluapunkt pullout might have had a positive electro wave go through due to a invalid code coming from the computer of your 05 town and country....
On a serious note we can’t guess your car, your deck model number type or anything else off of your post. Give more info so we can ask questions or give suggestions. |
Buy a bluetooth speaker. :)
The amps have a small gauge wire that turns them on and off. Check if it is giving you 12V AND that it is hooked up. I am gonna guess your amp for the speakers is fubared. Seems the sub amp is ok. Check by hooking up the sub amp to the speakers and vice versa. |
You can verify working speaker and wiring with a 9v battery, with the head unit or amp disconnected hold one wore to the battery and strike the other across the other battery terminal. It will make a pop sound and if you're looking at it visually move. If this fails you have a wiring issue or blown speakers.
You can test stereo and amp output with a test lamp. |
