Height, Width, Dimension Thread
For comparison's sake, I was curious about height, width and ground clearance measurements from different set ups. In the interest of having something tangible to see later, let's keep it to just the facts.
The points of inquiry are: -Width, outside of tire to outside of tire -Wheel model, width and back space -Suspension set up, whether it IFS, solid axle with/without spacers, etc. -Clearance to the bottom of the t-case crossmember, somewhat arbitrary but note if it is stock, aftermarket, etc. Perhaps similar set ups can then be compared Thanks. |
Not sure this is what you're looking for, since its not 2nd gen, but a bump anyway
Front-69.5" Rear 68.5" Tcase- 14.5" Wheel- steel 15x8, 4.5" back space, generic crap you buy at discount IFS TCase skid- budbuilt single case xmember w/skid. measurement off the back (lowest point). |
Yeah, tire too.
33x12.5 sorry
33x12.5 sorry
Chris |
Width: 71", 33x10.50 on 15x6 stock wheels, 3.38" backspace, w/ 1" wheel spacers
Height: 22", Raised Front Range crossmembe/skidplate |
This died quick! I'll get mine tonight to get back going again!
Chris |
Here's mine:
1) Width outside of tread to outside of tread: 68" 2) Wheels: Stock 1997 4runner 3) Suspension setup: - Front - Tundra Coils, top out spacer, OME shocks - Rear - LC 8 wrap coils, OME shocks, panhard drop, no rubber isolater cone 4) Height from ground to transfer case skid plate: 19 1/8" 5) Lowest point on rear bumper (Hitch tube): 27 3/4" 6) Bottom of sliders: 24 1/2" 7) Bottom of rear frame rails: 25" Adrian, do you have your new numbers since the SAS? Chris |
