Heater Core Replacement
Hey Y'all, I am fairly new to this site but have a question about replacement heater cores. I have a 1986 Toyota 4Runner, w/o rear heat, that I have completely torn the dash out and noticed that the heater core was quite rusted, so decided to replace it. What is the top replacement heater core since the factory core is no longer available? I bought a Spectra core but it just seem to fit right and is too short.
Go have stock one repaired. If there is a "best" replacement I haven't found it.
I don't think that the one in the 4runner is stock.
Originally Posted by toyobama
(Post 52392933)
Originally Posted by muddpigg
(Post 52392939)
sure, i’ll Bite. Is climate control unit modified? |
(Post 52392943)
No, it is not modified, at least I don't think it has been.
(Post 52392961)
it’s an oddball stock one. Take measurements of it to compare to replacement. I have found one that is same size but it wouldn’t mount to extension tubes. Have tried 4 different aftermarket units. This my experience leads to why my first post said take it to a radiator shop and have it repaired. I also had my extension tubes soldered to heater core. |
15x2.5mm if memory serves. Its on an old post of mine, can google. |
(Post 52393164)
If I remember silicon will work but hydrogenated silicon has a wider temp range |
(Post 52393168)
Believe so. But like I said find old post. IMHO you should replace spring c clips that hold extension tubes to core. Guessing a dealer only part. |
(Post 52393171)
I used a table to set core on. Pressed the tubes on with force, as square as possible, Had one of my minion helpers slide clip on while I compressed o-ring. It is frustrating and tedious but stick with it.
