guages???
Hey guys, I have a question for ya..So in my truck I have the gauge set with only the speedo...is there anyway to switch it and put the kind with the tach as well in there?? thanks
sure.
how?
is it very hard? i mean, how would i go about doing it?
Use the search feature at the top of the page. It's not that hard of a job at all, maybe an hour if you've never taken your dash apart before.
not hard, mine was plug and play.
Since you have a '90, I'm not sure 'bout your tach is connected to your speedo cable, but you will have to change your oil sending unit. That's rather easy, as well. If you have a stick, get a cluster out of a manual truck, if your an auto, get the cluster out of an auto.
search "SR5 gauge swap", it's been done many times.
It involves a few other changes other than just simply swapping out clusters, but it's doable |
