gear suggestions
Im currently in the middle of a sas on my 94 pickup. I am one of the few who has factory 4.88s so it feels great with my 33s I have on it now. I wanted to know what you think should I
A) Gear the front with 4.88s and run that Or B) Gear the front with 5.29s and get a new carrier for the rear and gear that too (you can?t regear the factory 4.88 carrier) Either way im going with duel cases in the future, what?s you impute? Thanks Steve also i wont be going with 35s until after the cases |
If I were you I'd just keep 4.88's in the rear...Wabbit ran 37's with 4.88's and claimed to have plenty of power on tap, so I'm guessing you'd be fine...
Can't forget about the added bonus of not having to find a completely different carrier and regearing :great: |
Yeah - you can't regear those thirds ... regearing's gonna be an expensive proposition for ya.
Note that all those trucks you're comparing to are manual tranny. (I assume you have an auto). You need to gear AT LEAST one step lower to accomodate the monster overdrive in the auto. |
i know i said that, but im not going to go bigger that 35s untill its strickly a trail rig so i may just live with it being a little slugish on the road
I would re-gear to 5.29's if it was me. As far as the carrier thing goes its just "the carrier" the rest of the third is fine. All you would need is a Detroit soft locker,Tru Trac,ARB or any other full carrier locker and you third would be fine with run of the mill 5.29's. I'm sure you could find some one with a spare open V6 carrier laying around that you could probably get for free as they get tossed out when you go to a full locker like most do.
Do lockers and gears once or you are paying labor twice. Gear for the future cause you'll want bigger tires...ask me how I know. With an auto...5.29s definitely for the future.
:guitar: |
Go with the 5.29s or even 5.71s with the auto/33s and get some good use out of that OD gear. You'll love them. :D
Originally Posted by Toy-SkiTzo
(Post 50383663)
A) Gear the front with 4.88s and run that Or B) Gear the front with 5.29s and get a new carrier for the rear and gear that too (you can?t regear the factory 4.88 carrier) Either way im going with duel cases in the future, what?s you impute? Thanks Steve also i wont be going with 35s until after the cases Were you running 33x10.5 or 33x12.5? |
Originally Posted by mt_goat
(Post 50383999)
oh yeah...5.29's seem to be the real popular choice. my buddy ran 37's on his 22r with an auto and it worked out real nice. Jon |
Originally Posted by jriebe
(Post 50485028)
mt goat...i have heard some really bad things about the 5.71's...just curious to know if you know something I don't?
Jon Check this out:http://www.gearinstalls.com/410suck.htm |
I would love to do a 3-D finite element analysis of a 4.10 R&P vs. a 5.71 R&P, specifically looking at stresses and deflections in the sets with a certain moment applied to the pinion shaft. It would take quite a bit of advanced friction coupling, and a pretty dense mesh, but I'm confident I could do it.
Problem is, where can I find a native 3-D model of a ring and pinion set? |
(Post 50485052)
Later, Jon |
Originally Posted by mastacox
(Post 50485060)
Problem is, where can I find a native 3-D model of a ring and pinion set? Can't you just draw one up on Pro-e? :bigok: |
(Post 50485070)
Maybe I should call up a gear maufacturer like Yukon and ask nicely for an IGES file... :nerd: |
I think it's a no brainer anyway, isn't it? I mean the thicker metal is going to show-up on the FEA run as less stress and deflection, right?
same question only changed a little
now i need the gears for my 86 4 runner (22re 5spd) i have one 4.88 diff and im thinking of going with 4.88s and 37in MT/Rs again or i have someone who wants my 4.88 diff for 225$ and that money will go twords 5.29s |
