gear ratio?
hi all, i'm new here. I did search, but i can't find anything. how do i find out the gear ratio of my differentials? is there something on the door sticker that would tell me - i looked but I didn't see anything that resembles an axle code...
it's a 1991 (06/91) reg cab long box 4x4 5 speed with auto hubs and 22R. thanks in advance if anyone can tell me my ratio or steer me in the right direction for the information. :) |
thanks
Read the Axle Code from the vehicle indentification plate.
first digit: ring gear diameter A 138mm B 145mm C 6.25" D 6.62" E 7.1" F 7.5" G 8" H 9" J 9.25" K 9.5" L 10.5" M 12.5" N 13.5" P 14" Q 12" R 162mm S 6.38" T 6.7" U 6" V 10.6" W 15.5" X 142mm Y 158mm Z 202mm - no ring gear = FWD Second, third digits: gear ratio 01 3.30 02 3.36 03 3.545 04 3.556 05 3.70 06 3.889 07 3.90 08 4.111 09 4.222 10 4.375 11 4.444 12 4.625 13 4.79 14 4.875 15 5.125 16 5.286 17 5.60 18 5.714 19 5.833 20 6.167 21 6.667 22 6.78 23 6.833 24 7.64 25 4.556 26 5.571 27 3.364 28 4.30 29 4.10 30 3.727 31 3.909 32 6.591 or 4.807 33 7.503 or 5.583 34 6.781 or 4.786 35 7.636 or 5.60 36 4.778 37 3.583 38 3.417 39 3.154 40 5.375 41 3.308 42 6.500 43 3.550 44 3.214 45 3.533 46 2.928 47 3.944 48 3.356 49 3.729 50 3.400 51 3.736 52 3.722 53 3.250 54 3.941 55 3.333 56 2.821 57 4.058 58 3.238 59 3.234 60 3.519 61 2.724 62 2.892 63 2.655 64 4.312 65 3.837 66 3.071 67 3.526 68 3.095 69 4.176 70 5.857 71 2.962 72 3.949 73 4.285 Fourth digit: no of pinions, ltd slip-yes/no Code pinions ls 2 2 no 3 2 yes 4 4 no 5 4 yes http://forums.toymods.org.au/index.p...t=0#msg_311760 http://www.toyodiy.com/parts/q.html |
The vehicle ID plate in on the drivers door jam. Are you sure you don't have a 22RE. I thought by 1989 all trucks and 4Runners sold in NA were 22RE (C/T) (or 3VZ)
thanks for the help guys. i am a newb to toyotas, i do apologize if i've posted this in the wrong place. yes it is a 22re, everytime i told someone it's a 22re, I've been corrected, and told it's a 22r.
