Fuel tank pickup and lines
Does anyone know where I can get the fuel tank part that holds the fuel pump pickup and return lines? Mine is rotted out from sitting for 12 years and I can't find anyone that sells that part. if I can't find that I will have to fab something or rig up some kind of aftermarket tank or substitute something else.
Thanks Matt |
toyomotorparts.com or toyotapartseast.com . Good Luck!
I went to a Toyota dealership to get mine.
It is called the fuel pump bracket.
If yours is no longer available you might be able to use a newer year just taking note of the difference in size. |
