YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   Fuel injector problems (https://www.yotatech.com/forums/f116/fuel-injector-problems-307240/)
Jens4runner Mar 14, 2019 12:55 PM
I'm having problems with my 91 4 runner is it possible to over tighten fuel injectors
snippits Mar 14, 2019 03:25 PM
What is the problem? Which engine?
Jens4runner Mar 15, 2019 05:06 AM
Injector problems
Its the 3vze 3.0 my husband rebuilt the injectors be we're wondering if you can over tighten them and if so what will happen if you do
ev13wt Mar 15, 2019 08:16 AM
Aren't they just stuck there between the intake and the fuel rail? As in they don't screw down?
https://www.yotatech.com/forums/f116...s-3vze-293282/
scope103 Mar 15, 2019 09:00 AM
Hard to imagine you could "over tighten" injectors.
Here's the manual; look at page 227 http://web.archive.org/web/201311071...90injector.pdf The fuel rail is tightened to only 9 ft-lbs (the rail has rubber isolators, so you COULD over tighten the rail. I'm not sure that would directly affect the injectors.) Note that you should be able to rotate the assembled injectors (the gasoline "lubricant" allows the o-ring to rotate). The manual advises that if you can't rotate them, you probably messed up the o-ring.
And if you did that, I would expect leaking.
Good luck!
