YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   Front Diff Oil (https://www.yotatech.com/forums/f116/front-diff-oil-208006/)
90toyo4runner Mar 25, 2010 07:57 PM
Front Diff Oil
my front diff says 75w90 gear oil on it, i was wondering if 80w90 gear oil would work, the reason i ask is i can get 80w90 for a couple bucks cheaper, also how much oil does the front diff hold? thanks for any help
yotaman85 Mar 25, 2010 07:58 PM
its fine, just fill it tell it overflows.
Teuf Mar 25, 2010 08:01 PM
I use 80/90 gear oil, no prob. Its either 1.6 front / 2.2 rear. Thats for an 88 4cyl. (ifs front)
90toyo4runner Mar 25, 2010 08:04 PM
sorry i forgot to say i have a 90 4runner v6 3.0 5sp 4x4
so pennsoil 80w90 gl-5 gear oil will work fine? i thought it might but the dealer said
" they recomend 75w90 for a reason"
Windsor Mar 25, 2010 08:43 PM
Originally Posted by 90toyo4runner (Post 51402715)
sorry i forgot to say i have a 90 4runner v6 3.0 5sp 4x4 so pennsoil 80w90 gl-5 gear oil will work fine? i thought it might but the dealer said " they recomend 75w90 for a reason"
GL-5 is perfect and 80w90 is perfectly fine (that's what I run, but in synthetic).
kenbo53 Mar 25, 2010 08:49 PM
it wont make difference, mabey as them what the reason is? ive been running a 50 50 mix of water and whatever grease the po had in it in my 87 since this summer waiting for it to crap out on me so i have some motivation to put the solid axle under it but so far its been staying strong haha i dont recomend that tho
flyingbrass Mar 25, 2010 09:04 PM
80w-90 GL-5 is fine for the diffs and transfer case.
GL-4 oil is better for the manual transmissions. The only dino version I've found is Sta-Lube sold at Napa.
