freeze plug leak in the back of 3VZE
True .. Here is another photo
I really hope I will not find a hole in the block
Was much dirt all across the Water Block line and heads line
Oil cooler pipe clogged with mud
I believe it was because the Owner beforee me used regular water
That coolant line is still available from Toyota, I replaced mine due to leaking about a year ago. Also, by all means, replace the knock sensor wire. They are cheap and also available from the dealer. You think the previous owner ran water alone in it? That would explain the rust. How many miles are on the rig?
06-01-2021 01:51 PM
Spicer
06-10-2020 08:39 PM
voiddweller
19
05-02-2016 09:10 PM
bigblue82
10
07-06-2015 08:27 AM
3vze, 4runner, back, freeze, freezplug, head, leak, located86toyota, measurement, pickup, plug, plugs, replacement, smell
