Factory security light won't go off after playing submarine
Alright well did some wheelin today and got into more than my poor yoter could handle. my 95 4runner sucked up a little water, got pulled out and back home. got the fluids changed and all that now the only issue is the security light wont shut off and the keyfob wont work... on top of that it will lock itself, is there a reset switch somewhere?
no but disconnect your battery with the lights on, wait like 30 seconds for the computer to reset and then connect your battery againg....it should work, if not then it is going to be something else..
You make sure you got all the water out of your spark plugs that are plugged into the engine? Also do you have diff breathers? if not you might need to change your diff oil as if water gets in the oil mixes and breaks down and your differentials can suffer...
FS[PacNorWest]: Factory Alloy Wheels - Bay area
94whiterunner
9
09-22-2015 07:28 PM
Hamonacracker
07-17-2015 08:33 AM
Odin
07-15-2015 09:28 PM
Johntom240
7
07-13-2015 12:18 AM
