YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   Factory Oil Filter (https://www.yotatech.com/forums/f116/factory-oil-filter-96495/)
BearsRunner Oct 5, 2006 04:32 PM
Factory Oil Filter
Well, Just recently switched from Fram Extra Gaurd to a Toyota Filter, And my Oil PSI increased from 5-7 psi at idle to 7-9 at idle, And while driving at 2700 rpm's in 4th gear at 55 my psi was about 12 1/2 and now it is close to 15 psi unless I am driving home up the mountain, then it is alittle lower.
I just thought I would share my little bit of news with you guy's. I alwasy find tons of good news and advice here at YT. Toyota's Rock!!
Bear
typical8o8 Oct 5, 2006 05:18 PM
yeah, Fram oil filters are not well regarded. if you want a good resource about oil, oil filters, air filters, etc check out the BITOG (bob is the oil guy) forums. lots of good info there.
Elton Oct 5, 2006 05:28 PM
yes any thing fram or bosch and champion suck and dont use them
