Extra Pink Wire in Instrument Cluster Connector
In working on the instrument cluster for the '85 diesel RV conversion the cluster itself uses "C" connector pin 4 for ground and 5 for the "FU" or fuel sensor. Both wires run to the fuel sensor itself. The actual "C" connector has a pink wire at pin 4 and the ground is on pin 5 and the "FU" is on pin 6. The cluster does not match these pins and pin 6 is not connected in the cluster itself. Does anyone know what the pink wire is? I can't find it on any of the schematics I have. (I moved the W/B wire to pin 4 and the Y/R wire to pin 5 on the connector to match the cluster).
steve miller
10-10-2015 01:40 AM
Esibnitsud
07-30-2015 08:21 PM
rushw
07-18-2015 01:46 PM
88yodabasket
07-13-2015 01:32 PM
