Engine...what did I do wrong!? DESPERATE
Ok, first off this is my THIRD profile. I cannot reset passwords or get into the others. No worries, i hav a lot of email addresses. :)
I pulled my head off after the gasket let go on cylinder #2. I didn't check the torque on the head bolts after the first 1000mi of new engine. They didn't need to be broken free when I removed the head. Here are bullet points to keep this easy to read.
WHEN I TRIED TO DRIVE IT, THERE WAS "NO PEDAL". THE TRUCK WOULD MOVE BUT FELT LIKE ALMOST NO POWER. I went down the street but turned around because it just didn't want to move. There was a very small spot in rev range where the truck felt like it had power. It jumped a little then fell back. There was oil running down the passenger side of the motor. Presumably from the oil filter but I couldn't really tell.
WHAT IN THE WORLD COULD THIS BE?! My rig has been sitting for 4 months now...PLEASE HELP!!! 1994 Hilux 22RE RV Cam Engine <8k miles (complete rebuild with new head and cam upgrade) No other mods |
Oh yeah, I forgot. Oil is NOT being forced out of the dipstick tube.
Have you put a timing light on it? You will know if its off or not. Start simple, double check vacuum hoses, check for vacuum leak with starter fluid, firing order, the simple cheap stuff. Have you replaced the fuel filter recently? Is it tripping any codes? They don't always flash a fault light.
Not tripping any codes
Have not tried a timing light yet. (would timing explain any of these problems other than no pedal?) vacuum hoses are good firing order is good Have not replaced the fuel filter. Hose was leaking...I just trimmed it back and reinstalled it. THANK YOU SO MUCH FOR REPLYING!!! |
Timing could explain a lot of it. Clean the oil up good and then drive it for a few minutes, or just let it idle. Find the oil leak, and confirm its from the oil filter. If not thats not a good thing to let go unchecked.
Remember timing controls you spark advance or retard. To early or late and it could be gutless and rough running. If you have a harbor freight near you their light are cheap and will get the job done. Im not great with these motors but have been through them a few times. Got about another hour at the airport before i board. So i will watch this for a bit. Good luck. |
It sounds like you are a tooth off on the timing chain
thanks guys! work has me hemmed up. hopefully I can get by to check this stuff before the weekend. (truck broke down near my buddies house so not just a quick run outside). I will post what I find!!!
My ideas:
Big vac leak, egr stuck open could do it. blocked inlet to AFM, not enough air= no power. if there is a plastic duct going from the air filter box to radiator support, make sure it's not blocked off.(ask me how I know) oil leak is unrelated. Timing retarded |
Timing..... Timing. ...https://cimg1.ibsrv.net/gimg/www.yot...079771e445.jpg#1@TDC.... LOOK at the button. 😥
Originally Posted by Hilux1994
(Post 52393141)
Bet both #1 valves are NOT closed now, but they will be when you turn the crank around again. Think what you're seeing is 100% normal. |
Originally Posted by millball
(Post 52393147)
Turn the crank another turn and it will come around. Crank turns TWICE for one rev of the cam.
(Post 52393148)
but at this point it is on #3 plug exactly. Turn the crank 1 more revolution to 0deg mark?
This won't tell you too much. You need to verify the marks on the cam are just short of 12 O'clock next. |
(Post 52393149)
Yes, that's exactly what I said. The rotor will come round another 180*, to near #1 position.
(Post 52393153)
On the timing light you cannot see the thinning mark at all. I will rotate the notch one more rotation. Brb
Have you verified that the cam position is correct when #1 cylinder is at top dead center with both valves closed??? |
I have not pulled the valve cover to check the cam. Idles at 750 and comes up to temp . Here is the crank after one more revolution. https://cimg9.ibsrv.net/gimg/www.yot...cc20119153.jpg
pulled valve cover. Timing is correct, top dead on the chain. Gotta start looking at the valve lashing etc now I guess. Never pulled a motor apart alone before. ....
(Post 52393159)
Here are some tips.. Put the distributor cap on, with a sharpie draw a line down the barrel of number one and on to the distributor for reference. If you go past the 0° timing mark you can not "just" turn it counter clockwise, you have to go all the way around again twice. If you go backwards the cam doesn't move due to the slack in the chain. When you insert the distributor you want the adjustment notch to be centered over the bolt hole.. Post pictures of the crank indicator, cam sprocket, and distributor after you put the reference line on it.. Buy, rent or borrow a timing light you absolutely need one, you can not just "eyeball" ignition timing. |
Thanks for all the help fellas. I have already pulled the valve cover off. I bought the harbor freight light and timing was good before I puked off the valve cover. Bad weather here now so anything more will have to wait. I'll keep you all posted!!
