engine problems
i have a 94 toyota pickup 4x4 22re automatic and have had some problems i cant seem to figure out. When i am under the hood and press the throttle fast the engine wants to stall out. it will stall out if i keep pressing the throttle quick. i donk know whats going on. tps is adjusted to specs. please help
fuel filter. unplug tps and see how it does.
i have replaced the fuel filter and when i unplug the tps the idle goes up and the truck runs fine. jus not good acceleratiaon. its an automatic so i need the tps plugged in for it to shift smoothly.
check all the simple stuff first.
Grounds plugs/ wires air filter clean throttle body make sure the tps is adjusted correctly only after all that is checked, you may have a bad tps or fuel pump |
you say the TPS is adjusted, but is the voltage reading right?
i have it adjusted correctly and it is a new tps. lets see how do you check the voltage with a digital meter. will it work the same as the analog meter? also i did say i washed my engine bay down and i believe it started right after that. the engine overheated once but it ran fine before i washed the bay down. and the tps was replaced after the engine bay was washed. One more problem the engine misses quite a bit when you keep it at a steady 2000 rpm... i dont kno?
Spay the electrical connections with wd40 because it may have gotten water in them .
there is no water in the plug. i sprayed some compressed air and blew out the conector. i still dont get the whole missing problem
take off distributor cap and look for moisture.sure sounds like your problem,
i have replaced the cap with a new one and i am sure there is no moisture in the cap.
what ever hapened to this thread? my 3.o has a low idel wh the TPS plug in and when its un pluged it idles just fine 800 I would realy like to know how this ended
:bang: what i find really frustrating about this thread is that everyone has a common problem, engine runs better without TPS. and in this whole thread no one actually went and double checked the TPS with a multimeter. i'm not saying the TPS is the problem but it sure sounds like it is worth checking if the motor runs better with it unplugged.
Originally Posted by 94toyotapickup321123
(Post 51330156)
here is a lesson for everyone, don't assume, go check, it is easy to do, and its better to be sure. |
| All times are GMT -8. The time now is 05:29 AM. |
