Engine install help!
Old May 22, 2021 | 12:25 PM
GreaseMonkey64's Avatar
I bought a 1991 forerunner that the previous owner removed the engine because of excessive rod knock and never installed a new engine. I picked up an engine localy and am currently installing it. My problem is i cant get the bottom of the bell housing to bolt up. I have the bolts in and the top bolts are almost complety on but there is a much more signinifgant gap between the engine and the bell housing on the bottom. I just cant get the gap to close. It takes quite a bit off force to tighten the bottom bolts and i dont want to break anything.
Old May 23, 2021 | 05:58 PM
fishnick's Avatar
You may need to lift the trans until they line up and slide them together. You don't want to pull them together with bolts. I like to leave the stiffener brackets a little loose and snug those bolts last, they use the 4 smaller bell housing bolts on the bottom.
Old May 24, 2021 | 04:54 AM
Hound Dawg's Avatar
5 Year Member
Rotate the torque converter until it goes all the way into the trans, should hear 2 or 3 clicks and it should go deeper in the housing. At least on american v8 thats what you need to do
shem
Old May 24, 2021 | 12:18 PM
ZARTT's Avatar
Hi:
A little more information would help.
Is it a 4 cylinder or a V6, automatic or manual shift, and did the donor engine come from an auto or manual shift?
Do not under any circumstance try to close the gap by bolting it closed, you will crack the bell, and cause big time bux.
Pls. reply so the forum can help you.
Art.
Old May 24, 2021 | 04:21 PM
It is an automatic. The engine that was in it was a v6 3.0 that is also what im installing. the donor engine was from a manual but i swapped over the flexplate.
Old May 24, 2021 | 04:31 PM
millball's Avatar
Did you remove the pilot bearing from the end of the crankshaft??
The torque convertor can't seat otherwise.
Hound Dawg's Avatar
5 Year Member
Pilot bearing in the way? Might still be in the motor end, did that before lol
shem
Old May 24, 2021 | 04:57 PM
Oh my gosh I thought it was out but I totally missed it. Makes perfect sense now.
Old May 24, 2021 | 05:01 PM
maxvp01's Avatar
IIRC On the 3VZE where the bottom 4 bolts go in are two brackets that attach to block. Two bolt holes per bracket. I had to loosen each bracket and thread everything in loosely before tightening it all up to make it work.
Old May 24, 2021 | 08:27 PM
Hound Dawg's Avatar
5 Year Member
Millball we posted the same thing at the same time lmao!
shem
Mwhite49
Sep 29, 2019 08:21 PM
ditypup
Aug 28, 2014 01:42 PM
Dauntless1971
Jun 17, 2013 09:08 PM
B4Runner
Dec 13, 2011 07:09 AM
ELD
Feb 20, 2006 06:02 PM
