thorrinn123 |
01-21-2011 08:20 AM |
Engine dies
I have a 92 V6 auto 4x4 4runner and have changed all fluids, done the timing belt, water pump, thermostat. Did the valve cover gaskets, pcv valve. It starts up fine idles fine but when i step on the gas hard and let off the gas it suddenly dies. Only thing i can think of is i was going to clean the maf (which it doesn't have i found out) just a AFM and undid those 2 screws you aren't supposed to touch, and pulled out the connector a little bit and put it back in. could this be my problem? i have a used one coming also a new 02 sensor as well. I tried to pull the codes but none were there? any thoughts where i should try to determine what is causing this???
