engine codes 32 and 41
I was wondering if anyone has had these codes before with their vehicle and what they did to fix it. This is the second time i have had this problem. It happened to me about a year ago and i had the tps replaced. It went away and then just last week the check engine light came on for 1 second and then went off. When I checked the codes i had a 32 and 41. Last night when I was on my way home it happened again. It came on, so I pulled off the road and sat for 30 minutes or so and it finally went off. Thanks
I'm guess its the 3.0L....
32: Volume Air Flow Meter Signal-open or short detected continuously for 0.5 sec. or more in VAFM circuit.-- Open-E2. Short- VS-VC. 41: Throttle Position Sensor Signal- Open or short detected in TPS signal (VTA) for .05 sec or more. IDL contact is ON and VTA output exceeds 1.45 V |
That's funny; all this in his sig yet no indication of engine or model of truck!
Cobra cb Dual 4’ black antennas Panasonic mp3 head unit Pioneer 760 watt amp 12" Rockford F&F sub Venom 400 Chip Cold air intake 31x10.5x15 Firestone Destination M/T 3" performance accessories body lift and gap guards rancho 9000xl shocks |
its a 3.0L. I found what the codes were but didn't know if anyone had ran across the same problem. thanks
Originally Posted by TNRabbit
(Post 51148927)
does the venom work?
yea, i personally think it does.
Originally Posted by rhino66549
(Post 51149588)
| All times are GMT -8. The time now is 07:19 AM. |
