YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   engine code (https://www.yotatech.com/forums/f116/engine-code-108023/)
Sonofmayhem Feb 21, 2007 06:11 PM
engine code
89 4runner 22re
code 51
what is it!
imtxn Feb 21, 2007 06:37 PM
code 51
5 short pause & 1......switch signol.....such as, a/c switch off, neutral start switch off, idle switch off during diag. check
mudbutt Feb 21, 2007 06:48 PM
if it is running and the a/c is off, then you don't have idle contacts in your TPS sensor. Check you adjustment, if you caqn't adjust it to have idle contacts then get a new tps.
Sonofmayhem Feb 21, 2007 06:54 PM
nice....... thanks
