This engine bottom end stuff is getting confusing.....
To the inexperienced, such as myself, it appears I have two different size cylinder in my 22re. The front two pistons have "Toyota" and "Art" stamped on them, while the back don't have this stamped on them. Also, they are numbered different.
What gives? Why do they have different size pistons? Thanks. vmax84 I'm just about done trying to figure all this out and simply take the block to the machinest, let him bore it, and rebuild the bottom end for me. I just don't want to goof it up. |
Two of the pistons are size 1, while the other two are size 2. What gives? Couldn't they simply have bored all the cylinders all the same size?
vmax84 |
Might it have been a cheapy reman engine at some point
Has anybody else ever discovered this when tearing an engine down.......two different types of pistons in their engine?
vmax84 |
Originally Posted by vmax84
(Post 50487126)
vmax84 |
Originally Posted by longhungsilver
(Post 50487486)
Yes i have vmax its not that unusual... For instance in a factory toyota from time to time there are slightly (very slightly) different size pistons used...toyota doesnt just slap a piston in a hole with .002 clearance extra... nono they take a slightly larger piston and use it to take up the slack... So its not super unusual for toyota and its definetly not unusual when an engine is 'rebuilt'
My buddy came over yesterday with his measuring devices, but I'm not 100% sure he was spot on with his diagnosis. He said we could get away with honing it. Looking at the cylinders with my untrained eyes, they do look real good for an engine with 175,000 miles on it, however, then purchasing the correct size rings, bearings, etc., is almost mind boggling to me. I am very fussy with my "toys". This 89 4runner I brought back from Texas almost two years ago will never see a Michigan winter, never see a mudhole, etc. I bought it simply to tool around in, to pull my 14' fishing boat, etc. My biggest concern so far is getting the bottom end solid on the truck. I don't have the confidence in myself to make sure all the measurements are correct, and after seeing my buddy kinda fumble around with the cylinder measurements, I lost a little confidence with him as well. I am really close to loading the block up and taking it to the machine shop. I just don't want to get the engine all put back together, bolted back in the truck, start it, and then listen to a low end knocking noise. vmax84 |
You should contact Ted (EB) for his expert opinion, his e-mail is in the link below:
http://www.engnbldr.com/ |
Originally Posted by mt_goat
(Post 50487645)
http://www.engnbldr.com/ Great guy, Ted. vmax84 |
Using different sized pistons.. lovely.
Misbalanced for sure. |
Originally Posted by dcg9381
(Post 50487670)
Misbalanced for sure. I guess that's part of the "x" in the equation for me.........irregular size pistons, or pistons "not quite" the same size. To me, although it's quite a bit more money, it just makes sense to take it to our good machine shop here in top, have them bore it so all the cylinders are the same size, and go with it from there. vmax84 |
thats the toyota way.makes for better fitment.just got my 3vz back in the truck.it has 3 "different main bearings & 2 different rod brngs.some say standard size will wrk but this engine had 300,000 miles on it & the original brngs didn't even have any copper showing.it was a no brainer for me to put factory stuff back in it.didn't rpl pistons either.machine shop said cyls were only .001-.002 over so i put the same pistons back in the same holes they were.looking forward to seeing how it does
Originally Posted by littlerunner
(Post 50487686)
As much as I love tearing stuff down and rebuilding it, I end up opting to have a shop build the bottom end. My father, who has been doing this stuff for nearly 50 years, is the same way. If ths same shop can machine it and put it together, then you end up with a consistent build. Not to mention someone to fall back on and blame if something is wrong :P If I am simply replacing a crank or something like that, then I would tackle it. But if an entire rebuild is taking place on my daily driver and machining is involved, I would just as soon get the short block back assembled and do the rest myself.
Originally Posted by engifineer
(Post 50487763)
Thanks a lot for all the good advice. vmax84 |
Vmax, good to see you doing it right.. What you're doing is the difference between a rebuild that will last 20k and one that will last 250k.
Find a *good* machinist also.. One hint for a good one is one that doesn't want to do final hone on the block until the pistons are in-hand... The pistons can vary in casting size and each one should be sized to it's particular hole. Engnbldr also has some decent writeups on quench and other suggestions that your machinist may not check out on these motors. Consider having it balanced - it's not critical, but if you're going to keep it forever it really calms down noise/vibration on idle. |
(Post 50487946)
Find a *good* machinist also.. One hint for a good one is one that doesn't want to do final hone on the block until the pistons are in-hand... The pistons can vary in casting size and each one should be sized to it's particular hole. Engnbldr also has some decent writeups on quench and other suggestions that your machinist may not check out on these motors. Consider having it balanced - it's not critical, but if you're going to keep it forever it really calms down noise/vibration on idle. Fortunately, we have a good machine shop here in town. They do really good work. Balanced? Any idea how much this costs? Thanks. vmax84 But yeah, I want this engine to last a long time and I really don't want to tear it out again!! |
Balancing (in Austin) runs anywhere from about $150-$300. As I stated, it's optional.. That motor will be a lot better if all the slugs are the same size!
(Post 50488640)
Thanks again. vmax84 |
The quote I got from a reputable machine shop here in Denver (they do lots of Toyotas) was about $1000. This was a complete rebuild of a 22R-E short block. Machine work was hot tank, check deck for flatness, bore cylinders, crank, rods, balance. New pistons, rings, bearings (not Toyota), freeze plugs. They would do the assembly, which I think is important so that they could adjust for tolerances if needed. I did not ask for the price on a line bore of the mains, which is a good thing to do. The labor vs. parts was bout 50/50.
Originally Posted by DaveInDenver
(Post 50488949)
Whoooo............good work ain't cheap, is it?!!! But if it's done right, it's worth every penny. vmax84 |
| All times are GMT -8. The time now is 02:15 AM. |
