Electrical issue
1990 Toyota Pickup 3.0
I'm Having an ongoing issue with my voltage dropping terribly while driving to the point of dying. I replaced the alternator with a new one and that didn't fix it. I just replaced the wire that runs from the fusible link to the battery and that didn't work. When I use my turn signals and power windows or even my headlights the battery gauge will drop. I've checked just about every ground I can see under the hood. Any other ideas would be greatly appreciated. Thanks! |
How old is your battery? Do you know if the battery is good?
Are the battery terminals super clean and shiny (best electrical connections are made when clean, shiny metal touches clean, shiny metal)? :safari: |
Battery Terminals
I'm going to replace the terminals tonight and see if that helps. My buddy gave me a red top optima and it have 12.5 volts so I would assume that it is a good battery.
An adequate battery, as long as it is charged, will hold up the voltage even with a dead alternator. So a voltage drop with headlights means the battery isn't charged, or isn't taking a charge.
This is easy to check. With engine off, measure the battery voltage at the terminals with your multimeter. Should be around 12.6v. Turn on the headlights. If the voltage drops below, oh, 12.3v then the battery isn't charged. Charge it, repeat. If it still drops, replace the battery (or take it to any parts store; they'll test it on their carbon-pile tester.) If the battery holds up but you have a voltage drop at the voltmeter (or anywhere else) with headlights, use your multimeter to find the bad connection. Just keep measuring voltage to negative terminal as you move closer to the current draw. When you pass the bad connection, the voltage will start dropping. |
Originally Posted by JohnnyAK
(Post 52381456)
I... My buddy gave me a red top optima and it have 12.5 volts so I would assume that it is a good battery.
I will definitely do a test on it tonight. Thanks
what part of Alaska Johnny? If you're anywhere near the Kenai area I'll help you out if I can.
+1 to getting a multi-meter, testing battery and making sure ALL connections are good. Repeat: ALL connections to alternator and battery, not just the cliched "check grounds".
Originally Posted by akwheeler
(Post 52381471)
I’m up here in Fairbanks or I’d take you up on that man
had my battery tested and it checked out. Replaced the terminals with new ones and that also didn’t help. What in the world could it possibly be ?
Got a meter? test for voltage at your battery with the engine on and off and post your results
So the battery before starting was 12.8v
Started the truck- it went to 12.3v turned on my hazards it bounced from 12.3v to 12.20v all in between. Turned the lights on with the hazards still going and it dropped to 12.15v sorry for taking so long to respond |
what that tells me is your battery was fully charged, but your alternator isn't doing anything to keep it charged. check the connections from the alternator to the battery for power loss/bad connections. test the voltage at the alternator and see if it matches the reading at the battery when running. if not, fix the bad connection if so, check the circuits that energize the alternator, (sorry I don't have a wiring diagram maybe someone else can chime in here).
(Post 52382438)
This is for 22REliable, but wires leading to alt should be the same. "IG" is the "wire that energizes the alt" https://www.yotatech.com/forums/f199...l#post52094780 |
AM2 and AM1 fuse
anyone have any insight on the Am2 30 amp fuse and the AM1 40 amp fuse ?
Fuse panel next to the battery |
Absolutely.
Do you have a question? AKWheeler had it right; your alternator is not charging. That's not AM1 or AM2 (which would take out a lot of other stuff, too.) Have you done the tests suggested? |
So I went ahead and put a new alternator into it again and now it’s working like it should. I don’t know if maybe I forgot to connect something when I replaced it last time but she’s back to working condition. Thanks everyone for the help.
Congrats, you are welcome!
Glad you got it working
(Post 52382535)
... now it’s working like it should... I don’t know if ...
Originally Posted by scope103
(Post 52382532)
...Have you done the tests suggested?
| All times are GMT -8. The time now is 10:32 PM. |
