Electric fan wiring
1 Attachment(s)
In the process of my motor rebuild in progress, I'm going to do something that I've wanted to do for a LONG time... ditch the mechanical driven fan and put on an electric fan.
I've got a question though. How have some of you guys wired you'rs up? See here's what I plan. I want to wire it in a way so that it'll kick on in 3 different ways: A) temp sencor (once the engine gets to a predetermined temp, the fan kicks on) B) AC on (comes on with I turn on my AC, to pull air through the condencor) C) manual override (I can opt to turn it on manually) Here's what I was thinking; tell me if you think it's a good idea and will work. Use a 3 position switch (on, off, on) in the cab to handle all of the controls. Up will be manual override on; direct kick-on to the fan relay. Middle will be manual override off; for those water crossings. Down will be fully automatic; will kick on with the AC or temp sencor. I'm not a nuB in wiring by any means, but I'm no schematic scholar either :roll: But does this quick schematic scetch I made look right? What makes this setup a little complicated is that it uses 2 different relays... it's the only way I can think up to isolate each trigger so that it works. The hole system is also a ground interrupt, turning on and off the ground to the fan, not the 12+ Attachment 196963 |
go by the flex a lite " varible speed control "
it does all that, cost about 80 bucks, and is plug and play. it also starts the fan at about 60% and increases as temp goes up which is a nice for those of us using the taurus fan which pulls lots of amps at start up |
I think you can do it without two relays. I've been running a Flex-a-lite fan for years now and have ran it with TWO different controls. The origianal control that came with my fan was mechanical and not very good. In the end it shorted out and fried itself...:hillbill: I picked up a fully digital, full temp adjustable control unit with A/C kick on from Advance auto(I think Napa sells the same kit) and it was like $60? I think. Any ways, the only mod I had to do was seal the ONE relay that plugs into the unit with some silicon to keep the water out. It has worked flawlessly for me. I would sugest you go this route BUT if you come up with your own control, rock on!!! :great: Maybe you can run just the one relay and tie both inputs in? Maybe put some diodes to prevent backfeed. Also, the ground on your switch is for it to be lighted right?
**ALSO, I must warn you now: depending on what fan you use(not sure if you bought one yet) you may risk breaking the fan with your A/C unit!!! For instance, my Black Magic 165 fan will get damage under hi torque with the A/C unit from motor roll!!!! The only way to prevent this is to limit the drivers motor mount!!!!! Either with a 4crawler special or a new motor mount like ones from Rockstomper. I got REALLY good at rebuilding my fan blades after buying a couple till I figured out what the deal was($35 from Summit). |
Your schematic shows it already, but do NOT wire it to anything but the battery. Draw down to the fuse block under the dash was so bad it would actually kill the engine at idle for me. Wired it straight to the battery: barely noticeable.
ooooh, yeah, I completely had a brain lapse about the fact that there are some controllers out there that'll do all this automatically :roll:
I was just thinking up the cheaper route, and how the actual wiring would go the only reason I had to use two relays is because if I'm not mistaken, the AC clutch engage wire is a + lead, and most temp probes are a ground interrupt, so I wouldn't be able to just tie to the two together and the ground on the switch is actually the input power. instead of turning on + power like most switches, it would actually turn on the - power to the relay to engage it (instead of the realy being constantly grounded on one of the coil/switching leads, it would have a constant + on one of the coil/switching leads) and yeah, I learned my lesson about needing to wire them directly from the battery with a relay, lol. back when I had my 87 Heep, whatever circut in it that controls the electric fan stoped working, so I directly wired a switch (just a switch) from the fuse box, to the switch, then right to the fan :roll: worked fine for a while, till one day the switch literelly cought on fire and melted on my way to school, lol |
check my post
mercury villager electric fan swap |
BBP: I'm interested in your set up. I was running the flexalite 165 or 164 (forget number)had the control board fry once. Another time had the motor kick up and break several blades against the PS tensioner. Have solved the motor flex, I love low low and 2 wheel for fishtaling around tight corners on tight trails :) Glad I packed the mechanic fan as a trail spare. If you have anymore information on the controller set I'd be interested, I'll spend sometime searching later, but if you got anything handy it would be appriciated.
If you play in the mud or do high water crossings make sure you have an off switch.
Originally Posted by muddpigg
(Post 51243605)
http://www.autozone.com/autozone/cat...mpressor+Works https://contentinfo.autozone.com/zne...33647/image/8/ Now, I'm pretty sure there's a wire for a manual switch in the harness there. I also put in a led indicator light in the cab to see when the fan comes on. Unless the motor is off you cant hear it run over my exhaust and tires! LOL! |
BBP: I drilled out my motor mount and placed a 3.5" length .5" dia grade 8 bolt. Makes putting the engine in like tetris. My t-case crossmember/skidplate accepts 2 mounts one on crawl box and one on t-case. When I first installed engine I left a little too much slack in the bolt but not no more:) will look for that kit.
here is the wiring diagram
wiring diagram for 2 speed electric fan
1 Attachment(s)
2 speed fan wiring
(Post 51243675)
