YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   Egr (https://www.yotatech.com/forums/f116/egr-114088/)
montanatoy Apr 25, 2007 11:12 AM
Egr
Can someone explain how to take the EGR valve apart to clean the filters. The cap looks like it might pry off, but I rather be sure before trying. Thanks
MudHippy Apr 25, 2007 11:40 AM
The EGR valve doesn't have any filters in it. The EGR vacuum modulator does, which does require opening the unit. It's not something I have messed with, yet. I have taken apart my EGR valve, just to see the inner workings. Not something I'd recommend, the top is crimped on with some sort of press that I don't have. Easy to get apart, tough to get back together. You can clean the EGR valve with a solvent bath. Make sure it is totally dry when your done.
Here's the 93 fsm pages for the EGR.
22re
http://personal.utulsa.edu/~nathan-b...18egrsyste.pdf
3vze
http://personal.utulsa.edu/~nathan-b...77exhaustg.pdf
montanatoy Apr 25, 2007 05:51 PM
Thanks for the quick reply. I will try to see how the egr vaccum modulator comes apart. That was what I was looking for.
JEBSR5 Apr 26, 2007 02:38 PM
If I remember right, the cap just snaps off and back on.
Kevin286 Apr 26, 2007 03:16 PM
EGR. You don't need no stink'n EGR. Take all that cr-- er stuff off.
Go with Canadian configuration.
:rockin: :rockin: :rockin:
